1st Lieutenant Posted June 6, 2011 Share Posted June 6, 2011 (edited) Устройство - Mio Moov S650. Версия СГ -- WinCE v.5.0 SP1 Скачал, установил, все ок, но не может соединится с сервером. History.txt соответствующий: 2011-06-06 13:24:46 --------------Start CityGuide-------------- 2011-06-06 13:24:59 TAri:connecting Internet:0 - ok 2011-06-06 13:25:00 TAri:service.probki.net:1966 - ok 2011-06-06 13:25:00 TAri:connecting socket:0 - ok 2011-06-06 13:25:00 TAri:connected socket:10050 - failed (net error) 2011-06-06 13:25:00 TAri:closing socket:0 - ok 2011-06-06 13:25:00 TAri:closed socket:-1 - failed (unknown error (1)) 2011-06-06 13:25:01 JamUpd:connecting Internet:0 - ok 2011-06-06 13:25:01 JamUpd:service.probki.net:1960 - ok 2011-06-06 13:25:01 JamUpd:connecting socket:0 - ok 2011-06-06 13:25:01 JamUpd:connected socket:10050 - failed (net error) 2011-06-06 13:25:01 JamUpd:OnSpJupFailure:2 - ok 2011-06-06 13:25:02 JamUpd:closing socket:0 - ok 2011-06-06 13:25:02 JamUpd:closed socket:-1 - failed (unknown error (1)) 2011-06-06 13:26:00 TAri:connecting Internet:0 - ok 2011-06-06 13:26:00 TAri:service.probki.net:1966 - ok 2011-06-06 13:26:00 TAri:connecting socket:0 - ok 2011-06-06 13:26:00 TAri:connected socket:10050 - failed (net error) 2011-06-06 13:26:00 TAri:closing socket:0 - ok 2011-06-06 13:26:00 TAri:closed socket:-1 - failed (unknown error (1)) 2011-06-06 13:27:00 TAri:connecting Internet:0 - ok 2011-06-06 13:27:01 TAri:service.probki.net:1966 - ok 2011-06-06 13:27:01 TAri:connecting socket:0 - ok 2011-06-06 13:27:01 TAri:connected socket:10050 - failed (net error) 2011-06-06 13:27:01 TAri:closing socket:0 - ok 2011-06-06 13:27:01 TAri:closed socket:-1 - failed (unknown error (1)) 2011-06-06 13:28:00 TAri:connecting Internet:0 - ok 2011-06-06 13:28:01 TAri:service.probki.net:1966 - ok 2011-06-06 13:28:01 TAri:connecting socket:0 - ok 2011-06-06 13:28:01 TAri:connected socket:10050 - failed (net error) 2011-06-06 13:28:01 TAri:closing socket:0 - ok 2011-06-06 13:28:01 TAri:closed socket:-1 - failed (unknown error (1)) 2011-06-06 13:28:01 JamUpd:connecting Internet:0 - ok 2011-06-06 13:28:02 JamUpd:service.probki.net:1960 - ok 2011-06-06 13:28:02 JamUpd:connecting socket:0 - ok 2011-06-06 13:28:02 JamUpd:connected socket:10050 - failed (net error) 2011-06-06 13:28:02 JamUpd:OnSpJupFailure:2 - ok 2011-06-06 13:28:02 JamUpd:closing socket:0 - ok Соединение должно быть по BT. Все настроено, телефон нормально выходит в и-нет, но при включенном ситиГИДе работает только как hends free. Новител при тех же настройках спокойно выходил в интернет... Кто знает где копать? Edited June 6, 2011 by 1st Lieutenant Link to post Share on other sites
nectop Posted June 6, 2011 Share Posted June 6, 2011 В настройках СитиГид стоит "использовать дозвон"? Link to post Share on other sites
1st Lieutenant Posted June 6, 2011 Author Share Posted June 6, 2011 В настройках СитиГид стоит "использовать дозвон"? Там почему-то только одна опция "нет"... может это в .ini файле можно проставить? Link to post Share on other sites
nectop Posted June 7, 2011 Share Posted June 7, 2011 Если стоит нет,то скорее всего, не настроен DUN профиль. Link to post Share on other sites
1st Lieutenant Posted June 7, 2011 Author Share Posted June 7, 2011 Хм... Где? WinCE? Так Novitel из соседней папки выходиит на ура. В CG? А где там настроить? Поменял в .ini файле свойство DialUpUse с 0 на 1, в "использовать дозвон" кроме "нет" появилась опция "anwsoft". Но не помогло... :( Link to post Share on other sites
nectop Posted June 7, 2011 Share Posted June 7, 2011 В системе WinCE надо проверять. Link to post Share on other sites
1st Lieutenant Posted June 7, 2011 Author Share Posted June 7, 2011 В системе WinCE надо проверять. Настраивал всеми способами (автоматическое копирование с телефона, настройки оператора). Во всех случаях CG оставался безучастен к телефону. Правильность настрек проверял. И, опять-таки, новител спокойно разрывает hends free, и подключается к интернету. Пробовал не позволять использовать новигатор как аудиоустройство, но даже в этом случае CG не запрашивал GPRS соединения. Link to post Share on other sites
nectop Posted June 7, 2011 Share Posted June 7, 2011 GPRS соединение должно быть настроено в системе. Как в Вашем устройстве настраивается, сказать сложно. Link to post Share on other sites
1st Lieutenant Posted June 7, 2011 Author Share Posted June 7, 2011 Чудес не бывает. Все настройки в системе есть. Просто открыть GPRS соединение в самом устройстве нельзя (можно только hends free), можно его только настроить. В момент запуска навител разрывает hends free, и открывает GPRS согласно системным настройкам. CG так не делает. Судя по опции "использовать дозвон" он просто не знает о том, что эти настройки сущесвуют. В каком месте WinCE он их ищет? Link to post Share on other sites
nectop Posted June 7, 2011 Share Posted June 7, 2011 Сложно сказать, это обычно реестр, но так как WinCE система для сбора на ней устройств, то все производители меняют и хранят данные по разному. Думаю, Вам стоит выйти из интерфейса навигатора в Windows и посмотреть, что в системе. Link to post Share on other sites
1st Lieutenant Posted June 8, 2011 Author Share Posted June 8, 2011 В общем, запустить \Windows\explorer.exe на навигаторе у меня не получилось. Видимо, я не умею его готовить… Правда, попутно нарисовалось следующее решение: 1) Устанавливаем CG в отдельную папку (не трогая навиел) 2) открываем файл My Flash Disk\Program files\MainShell\BUTTONS.XML в текстовом редакторе 3) выбираем кнопку, которую не жалко (в моем случае это Media) и заменяем путь вызова (\My Flash Disk\Program Files\MioMediaPlayer\MioMediaPlayer.exe) на пусть к CG (\My Flash Disk\CityGuide_INET\CityGuideCE.exe) 4) запускаем navitel и ждем, пока он подключит GPRS-соединение. 5) выходим из навитела и запускаем CG (быстро, пока не разорвалось соединение GPRS ) 6) enjoy! Но это все-таки не то место, через которое удаляют гланды. Мне удалось узнать, что всем букетом Bluetooth-соединений заведует приложение MioBT. Но найти с какими параметрами его запустить, что бы получить GPRS-соединение мне не удалось... может кто знает? Link to post Share on other sites
victor946 Posted June 8, 2011 Share Posted June 8, 2011 вот вот тоже мучаюсь уже целый месяц: запускаю навител, выгружаю а потом запускаю CG. Может найдётся умный человек и разберётся как сделать всё "красиво" :rolleyes: Link to post Share on other sites
